When using multiple cameras, the response of ComputeDisparityMap becomes very slow
Continuing the discussion from How to use a common hardware trigger with multiple cameras:
  • Serial Number: 244888, 245218
  • Operating System: Windows 10 64bit
  • Data Attachments
As in the code below, we open two C57 cameras, specify hardware triggers for each, execute the Trigger and Retrieve commands, and then execute the ComputeDisparityMap command.
	nxLibSetString(&error, "/Execute/Parameters/Cameras", m_serial);
	nxLibSetString(&error, "/Execute/Command", "Open");
	nxLibSetString(&error, "/Execute/Parameters/Cameras", m_serial2);
	nxLibSetString(&error, "/Execute/Parameters/Cameras", m_serial_C);
	nxLibWaitForType(&error, "/Execute/Command", NxLibItemTypeNull, 1);
	nxLibSetString(&error, "/Execute/Parameters/Cameras", m_serial_C2);
	NxLibCommand trigger(cmdTrigger);
	trigger.parameters()[itmSubset] = valAll;
	trigger.execute();
	NxLibCommand retrieve(cmdRetrieve);
	retrieve.parameters()[itmTimeout] = -1;
	retrieve.parameters()[itmCameras][0] = m_serial;
	retrieve.parameters()[itmCameras][1] = m_serial2;
	retrieve.execute(static_cast<bool>(false));
	while (1) {
		std::this_thread::sleep_for(std::chrono::microseconds(10));
		if (retrieve.finished()) {
			retrieve.assertSuccessful();
			assert(retrieve.result()[m_serial][itmRetrieved].asBool());
			assert(retrieve.result()[m_serial2][itmRetrieved].asBool());
			bool rc2 = retrieve.result()[m_serial2][itmRetrieved].asBool();
			if (rc2) {
				break;
		if(cancel){
			retrieve.cancel();
			while (true) {
					return(1);
	retrieve.parameters()[itmTimeout] = 1000;
	retrieve.parameters()[itmCameras][0] = m_serial_C;
	retrieve.parameters()[itmCameras][1] = m_serial_C2;
	retrieve.execute();
	nxLibSetString(&error, "/Execute/Command", "ComputeDisparityMap");
	nxLibSetString(&error, "/Execute/Command", "ComputePointMap");
However, it takes more than a minute for the ComputeDisparityMap command to complete.
(We are waiting for a response with
nxLibWaitForType(&error, “/Execute/Command”, NxLibItemTypeNull, 1);)
Is there something wrong with how we are using it?
I am attaching the profile obtained at that time.
The single-camera version of the above code works normally.
Dear Techno,
We have never seen such strange behavior before. Note that the computation of the disparity map takes a very long time every second time. The first takes about 40 ms, and the second takes about one minute.
It would be helpful if you
  • record a file-camera,
  • check that the effect is reproducible for this file-camera,
  • share this file-camera with us.
Meanwhile, you can try updating to the next version of the SDK.
Best wishes,
Grisha
HI Grisha.
The phenomenon is occurring constantly during the test,
20260427101210.enscam (24.9 MB)
and we have the filecamera generated at that time, so I am attaching it.
Could you please take a look?
Thank you very much.
Dear Techno,
We tested both of your file-cameras on Linux, Windows 10, and Windows 11 and found no issues. Both calls of PatchMatch stereo-matching were processed in approximately the same amount of time. Here is an example from Windows 10.
In your profiling record, I noticed that not only did PatchMatch stereo matching start working very slowly, but the location cycle is also very unstable. I’m pretty sure there’s software on your computer that de-prioritizes processes with long-term, high CPU usage. It could be MS Defender, a firewall, or an antivirus program. Disable all of them, increase the priority of your process (e.g., in Task Manager), and take new measurements.
Were you able to reproduce the long delay with your file-cameras in NxView?
Best wishes,
Grisha
HI Grisha.
I apologize for the late reply.
I tested the two file cameras I sent using my custom software, but I was unable to reproduce the same phenomenon as you described at the site. Currently, I am unable to access the site for some time due to other reasons. The two cameras will arrive within a few days, and I will attempt to reproduce the issue in the office using a different PC than the one used at the site.
Also, I haven’t added any antivirus software since purchasing the PC. Therefore, the next time I’m able to work on-site, I’ll try disabling MS Defender and a firewall.
I will report back once I have received the two cameras and confirmed they are working correctly.
Incidentally, when capturing images on-site, we connected one sensor to both cameras as a hardware trigger. However, after one camera’s projector lit up, the other camera’s projector lit up 0.5 to 1.0 seconds later. Is this also something that can be confirmed with the profile I sent? Ideally, both cameras’ projectors should light up simultaneously, but is this timing difference also due to MS Defender or something similar?
One more question, please. In my custom software, I’ve set the same camera parameters for two cameras, as shown in the code below.
if (!selectfile.Open(LoadDlg.GetPathName(), CFile::modeRead | CFile::typeText)) {
	selectfile.Read((LPVOID)(&jsonbuf), sizeof(jsonbuf));
	selectfile.Close();
	sprintf_s(path, sizeof(path), "/Cameras/%s", m_serial);
	nxLibSetJson(&error, path, jsonbuf, NXLIBTRUE);
	sprintf_s(path, sizeof(path), "/Cameras/%s", m_serial2);
These parameters were adjusted in NxView while Camera 1 was connected.
My question is:
By using the same parameters for Camera 2 as for Camera 1, am I inadvertently changing values ​​specific to Camera 2?
Could this be causing ComputeDisparityMap to slow down?
Thank you for your understanding.
HI Grisha.
I was able to test it on a field PC, so I will report the results.
I don’t have any security software installed, so I disabled Windows Defender and Windows Firewall, but the problem persisted.
I also increased the priority in Task Manager, but the problem remained unchanged.
When I switch back to using only one camera, I can create parallax data normally.
For reference, the CPU of the problematic PC is
Intel(R) Core™ i7-9700TE CPU @ 1.80GHz.
The CPU of the PC that did not experience the problem
Intel(R) Core™ i9-10900K CPU @ 3.70GHz.
Is there anything else I should check?
Also, if I were to try upgrading the SDK version to see if it would help, which version should I upgrade to?
Thank you in advance for your help.
p.s.
When I selected two cameras in NxView and activated the software trigger, I didn’t notice any significant decrease in processing speed. However, when using hardware triggering with FallingEdge, the projector LED lit up and it appeared to be captured, but the displayed image barely updated. I wasn’t sure if the capture or parallax data creation was actually happening. I’ve attached the JSON file configured in NxView.
cam1.json (17.0 KB)
cam2.json (17.0 KB)
color.json (5.5 KB)
Could there be an error in the function call?
Dear Techno,
Sorry for the delay. Let me summarize the current state.
Ensenso setup:
  • Non-problematic case: one C57-6-M camera.
  • Problematic case: two C57-6-M cameras used with hardware trigger.
Problem:
  • The second call to ComputeDisparityMap takes pathologically long.
Software setup:
  • Ensenso SDK version: 4.0.1502.
  • Windows 10 64-bit.
  • No additional security software installed.
  • Windows Defender and Windows Firewall disabled.
Hardware setup:
  • Off-site:
    • i9-10900K CPU.
    • No problems. Everything works with both software and hardware trigger.
  • On-site:
    • i7-9700TE CPU.
    • Everything works with software trigger in NxView.
    • The problem always appears with hardware trigger, both in NxView and in your custom software.
Is this correct?
If this summary is correct, then the problem appears only on your single on-site setup and only with hardware trigger. Therefore, there seem to be two main possibilities:
  • there is a serious problem with hardware triggering on our side;
  • or the problem is specific to your on-site setup.
I will investigate the first possibility, but you can also try the following.
Stereo matching usually allocates a lot of memory. We keep such allocations in a finite LRU cache, which controls lifetime, priorities, and available memory. Your on-site setup seems to be much weaker than the off-site setup, since it uses a low-power embedded CPU. There is a slight possibility that the second call to ComputeDisparityMap does not reuse the preallocated memory. In that case, it may try to allocate its own buffers and then start swapping to disk.
Could you monitor the memory usage, swap/page-file usage, and disk activity on the on-site machine during the slow second call?
Best wishes,
Grisha
HI Grisha.
After various tests, it appears that the PC has reached its performance limits,
so we are planning to switch to a different PC for further testing.
However, due to the current global situation, the delivery time for a replacement PC
that can withstand the field environment is long, and testing will not be possible for some time.
I will close this question for now and ask again when testing resumes.
Thank you very much for all your responses.
I look forward to your assistance again when testing resumes.
