We just released Ensenso SDK 4.4 and B/C/CR-series firmware 2.1. They are available from the download page.
[!info] Changelog
You can find the complete changelog in the manual.
C67-Series
Add full support for the new C67-series devices with firmware version 2.1. The C67-series features a faster 5 Gbit/s network interface and an improved 8 MP color sensor.
Ensenso Scout
The new Ensenso Scout website helps with choosing the best camera model for your application. It also provides PDF datasheets of individual camera models for download. Scout is also available as stand-alone application within the SDK.
HDR
B-, C- and CR-series cameras now support a high dynamic range mode combining two exposures into a single image, computed on the device. This improves imaging performance in difficult scenes with regions of different brightness or reflections.
Histogram-based Automatic Brightness Control
Automatic brightness control now uses an improved algorithm based on brightness quantiles. This improves exposure regulation, especially on scenes with small bright or dark regions. It can also automatically enable HDR when it detects a large brightness range in the scene.
TCP-based Network Connection
B-, C- and CR-series devices now use TCP-based network connection by default, which is more reliable under suboptimal network conditions and removes the need for jumbo frames. When the camera IP address is known in advance, only a single TCP port is needed to communicate with the device, which eases routing and firewalling, e.g. when connecting to cameras from containers.
Direct CUDA Buffer Access
The new CopyGpuBuffer command allows direct access to disparity maps computed on the GPU, saving a costly data copy round-trip when processing is done on the GPU anyway. See the CUDA guide for an example.
GenTL Producer
- The GenTL producer now allows controlling the white balance of texture images from GenICam.
- There are new GenICam features which allow direct access to the underlying NxLib API. This can be used to access any camera parameters which are not wrapped in the GenTL producer.
PTP Synchronization
- The trigger delay for PTP-synchronized triggers can now be adjusted to your network setup.
- The PTP master clock timestamp at which an image was exposed is now published in the NxLib tree.
Other New Features
- Improved quality of PatchMatch stereo matching on B57-GN models with color sensors.
- SaveModel can write PCD files with texture and normals.
See the changelog for a complete list of changes and bugfixes in this release.
