TriggerDelay with C57 not applicable?
  • Product: C57
  • Serial Number: 231912, 232204
  • Ensenso SDK Version:4.1.1033
I want to apply a trigger delay for a multi camera setup with 2x C57 to avoid overlapping projector patterns. My idea was to set the camera parameter “TriggerDelay
In NxTreeEdit the node “TriggerDelay” is missing. (I tried opening the comple C57 and stereocamera only). With an N36, the node is present and works as intended.
Is there a way to apply a trigger delay for C57 cameras?
you are correct. Trigger Delay is not available for cameras of C and B series. I create an issue so that this will be implemented.
Joel
Hi Joel,
I got the same question from my customer, and we both spent quite a bit of time trying to figure it out.
Would it be possible to add a quick note in the TriggerDelay section of the manual saying that it’s not supported for the C and B series? I think that would really help others avoid the same confusion.
Thanks a lot!
we already implemented it and it will be available with the next SDK version.
Hello Daniel,
Thank you for your feedback.
I look forward to the next SDK release.
