Run Partfinder with a loaded PointMap
  • Serial Number: 232192
We wanted to know if its possible to run Partfinder with a previously captured PointMap (or whatever needs to be saved).
So we could automatically test new match settings on a database of older captures.
We currently tested the Partfinder using .stl files and it worked great.
Does it make use of the color information internally even if we not supplied object texture?
Thanks in advance,
René Horstmann
Hi René,
we are glad to hear that you are satisfied with our PartFinder.
In order to work with older captures you can create a FileCamera, which you can then open in NxView and run PartFinder on it.
The color information is not used, yet. The feature, however, has been implemented and will be part of SDK 4.1.
Benjamin
