Hi Team,
Can you give me some advice on this question?
- Product: C57
When the number of columns in the PLY file output after ComputePointMap is X, or the number of columns in an array with NaN points removed, when RenderPointMap is performed the number of arrays is much less than X. Is this because of the specification?
Does this mean 1) the point cloud is thinned out based on the concept of voxels, or 2) points that are not visible due to viewpoints such as ViewPose are thinned out?
If it’s reason 2), I think color information will not be added unless you save the PLY after performing RenderPointMap. In order to add color information, points behind the point closest to the camera in XY positions in the generated point cloud cannot be rendered, so will points with the same or very close XY positions, but different only in Z depth, be deleted, leaving only the point closest to the camera?
Warm regards, Kenzo
