Thank you for your answer. To answer your questions:
I cannot find the camera with the Network Wizard. But my network is correctly configured according to the Network Wizard.
The status LED is slowly flashing green, and I see some traffic with the yellow led
When using another PC, I can connect with the camera when I use the network wizard for the first time. However, when I disconnect the switch, I lose connection and can’t reconnect.
Reconnecting after unplugging the Ethernet cable from the switch to my PC results in the same problem
I cannot power the camera without PoE
When switching to DHCP, the camera gets an invalid IP and the network wizard forces a valid IP to the camera
No other warnings are shown.
"CUDA": {
"Available": true,
"Device": 0,
"Devices": [
"ClockRate": 1785,
"ComputeCapability": "8.9",
"Cores": 3072,
"Integrated": false,
"Memory": 7933,
"Name": "NVIDIA RTX 2000 Ada Generation Laptop GPU"
"Enabled": true,
"ErrorText": "",
"StaticBuffers": 2,
"UseFloat16": false,
"Version": 12040
"Calibration": {
"AssemblyCalibration": null,
"Pattern": {
"GridSpacing": 12.5,
"PatternBuffer": {
"All": {
"Filter": {
"Invert": false,
"Or": [
"And": [
"Invert": false,
"Type": "Static",
"Value": true
"Invert": false
"PatternCount": 0,
"ShowPatternPoints": false,
"ShowPatterns": false,
"StereoPatternCount": 0
"Thickness": 0,
"Type": ""
"Cameras": {
"245138": {
"EepromId": 1,
"Link": {
"Target": "Workspace"
"ModelName": "N36-602-16-BL",
"Sensor": {
"FirmwareUpdateVersion": "2.30.17079",
"FirmwareVersion": "2.30.17079",
"ModelName": "GV-50C2TE-M",
"Port": {
"Bandwidth": 1000,
"DHCP": false,
"Gateway": null,
"IpAddress": "10.0.1.254",
"IpSubnetMask": "255.255.255.0",
"MAC": "00:1b:a2:20:bc:03",
"NetworkAdapter": {
"Gateway": null,
"IpAddress": "10.0.1.2",
"MAC": "2c:58:b9:6a:24:e7",
"MaximumTransmissionUnit": 9000,
"Name": "eno1"
"Type": "Ethernet"
"SerialNumber": "9800551421"
"SerialNumber": "245138",
"Status": {
"Available": true,
"Calibrated": true,
"FirmwareSupportsModel": true,
"IsApprovedFirmwareVersion": true,
"IsSuppliedFirmwareVersion": true,
"LocalEepromFile": false,
"LowBandwidth": false,
"Open": false,
"Overtemperature": false,
"Paired": true,
"ValidCameraFirmware": true,
"ValidFirmware": true,
"ValidIpAddress": true,
"ValidProjectorFirmware": true
"Type": "Stereo"
"ByEepromId": [
null,
"/Cameras/245138"
"Debug": {
"BacklogSize": 20971520,
"FileOutput": {
"Enabled": false,
"FilePrefix": "log_",
"FolderPath": ".",
"MaxFileSize": 10000000,
"MaxTotalSize": 50000000,
"WriteFrequency": 1
"Level": "Off",
"StaticBufferSize": 4194304
"DefaultParameters": {
"All": {
"OpenMP": {
"Dynamic": 1
"Threads": 20
"ComputeDisparityMap": {
"StaticBuffers": 2
"RenderPointMap": {
"Far": 10000,
"Near": -10000,
"PixelSize": 1,
"Scaling": 1,
"Size": [
1024,
768
"Texture": true,
"UseOpenGL": true,
"ViewPose": {
"Rotation": {
"Angle": 0,
"Axis": [
1,
0,
0
"Translation": [
0,
0,
0
"RenderView": {
"ShowCameras": true,
"ShowGrid": true,
"ShowNormals": true,
"ShowSurface": true,
"ShowUserDefinedModels": true,
"Size": [
1024,
768
"ViewPose": {
"Rotation": {
"Angle": 1.217116005923658983,
"Axis": [
0.742906056031044759,
0.307721763977165164,
0.594472798273545933
"Translation": [
-1000,
1000,
-1000
"Execute": {
"Default": {
"Command": null,
"Parameters": null,
"PersistentParameters": false,
"Result": null,
"Status": {
"LatestMessage": null,
"Messages": [
"Progress": null,
"Time": null
"Images": {
"RenderPointMap": null,
"RenderPointMapTexture": null,
"RenderView": 13374071116.06401824951171875
"Interface": {
"Ethernet": {
"Adapters": [
"Active": true,
"Bandwidth": 0,
"Gateway": null,
"IpAddress": "172.18.0.1",
"IpSubnetMask": "255.255.0.0",
"MAC": "02:42:cb:58:10:3d",
"MaximumTransmissionUnit": 1500,
"Name": "br-49d4ae693d0b",
"Status": {
"CableConnected": false,
"Connected": true,
"Errors": "",
"LinkLocalIpAddress": false,
"ReversePathFiltering": false,
"Virtual": true
"Active": true,
"Bandwidth": 10000,
"Gateway": null,
"IpAddress": "172.19.0.1",
"MAC": "02:42:55:13:b5:a0",
"Name": "br-ef5107cdbe5a",
"Status": {
"CableConnected": true,
"Connected": true,
"Errors": "",
"Virtual": true
"Active": true,
"Bandwidth": 0,
"Gateway": null,
"IpAddress": "172.17.0.1",
"MAC": "02:42:c0:21:92:3b",
"Name": "docker0",
"Status": {
"Connected": true,
"Errors": "",
"Virtual": true
"Active": true,
"Bandwidth": 1000,
"Gateway": null,
"Name": "eno1",
"Status": {
"Connected": true,
"Errors": "",
"Virtual": false
"Active": true,
"Bandwidth": 1000,
"Gateway": null,
"IpAddress": "10.0.0.2",
"MAC": "2c:58:b9:6a:24:e8",
"Name": "enp58s0",
"Status": {
"Connected": true,
"Errors": "",
"Virtual": false
"Active": true,
"Bandwidth": 10000,
"Gateway": null,
"IpAddress": null,
"IpSubnetMask": null,
"MAC": "c6:d2:90:e2:ff:48",
"Name": "veth0562aa4",
"Status": {
"Connected": false,
"Errors": "IP configuration is not in the private address range.",
"ValidIpAddress": false
"Virtual": true
"Active": true,
"Bandwidth": 10000,
"Gateway": null,
"IpAddress": null,
"MAC": "72:d1:d2:65:a6:71",
"Name": "veth069b386",
"Status": {
"Connected": false,
"Virtual": true
"Active": true,
"Bandwidth": 10000,
"Gateway": null,
"IpAddress": null,
"MAC": "a2:d5:83:e0:cb:5c",
"Name": "veth1463e51",
"Status": {
"Connected": false,
"Virtual": true
"Active": true,
"Bandwidth": 10000,
"Gateway": null,
"IpAddress": null,
"MAC": "c6:7a:83:33:05:bd",
"Name": "veth42f6e80",
"Status": {
"Connected": false,
"Virtual": true
"Active": true,
"Bandwidth": 10000,
"Gateway": null,
"IpAddress": null,
"MAC": "42:3b:6c:53:b9:e5",
"Name": "vethc9acbcb",
"Status": {
"Connected": false,
"Virtual": true
"Active": true,
"Bandwidth": 10000,
"Gateway": null,
"IpAddress": null,
"MAC": "ee:11:f4:f2:4b:70",
"Name": "vethcda8d40",
"Status": {
"Connected": false,
"Virtual": true
"Active": true,
"Bandwidth": 10000,
"Gateway": null,
"IpAddress": null,
"MAC": "5e:58:54:fb:96:04",
"Name": "vethd19b7b4",
"Status": {
"Connected": false,
"Virtual": true
"Active": true,
"Bandwidth": 10000,
"Gateway": null,
"IpAddress": null,
"MAC": "06:90:6e:b6:2d:f4",
"Name": "vethf7b04b7",
"Status": {
"Connected": false,
"Virtual": true
"Active": true,
"Bandwidth": 0,
"DHCP": true,
"Gateway": "10.0.10.1",
"IpAddress": "10.0.10.84",
"MAC": "c8:15:4e:f7:57:c9",
"Name": "wlp0s20f3",
"Status": {
"Connected": true,
"Errors": "",
"Virtual": false
"Links": {
"Objects": null,
"Parameters": {
"PartFinderObjects": null,
"PartFinderSelectedObjects": null,
"Physics": {
"Gravity": [
0,
0,
100
"GroundPlane": false
"UEye": null,
"Version": {
"CodeMeter": {
"HasLicense": false,
"Status": "CodeMeter API could not be loaded."
"FirmwareVersion": {
"B5x": {
"Build": 0,
"Major": 1,
"Minor": 3
"C5x": {
"Build": 0,
"Major": 1,
"Minor": 3
"NxLib": {
"Build": 1502,
"Day": 13,
"Hash": "751abfc4b72d9551e808ef1e63335323138bf7ac",
"Major": 4,
"Minor": 0,
"Month": 8,
"Year": 24
"PartFinder": {
"HasLicense": false
"Projector": {
"Application": 37,
"Bootloader": 18
"RayTracing": {
"HasLicense": false
"SystemInfo": {
"Architecture": "x64",
"CPU": {
"Cores": 20,
"Feature": {
"Avx2": true,
"PopCnt": true
"Threads": 28
"CUDA": {
"Devices": [
"ClockRate": 1785,
"Cores": 3072,
"Memory": 7933,
"ErrorText": "",
"Version": 12040
"Memory": 31692,
"OperatingSystem": "Linux"
"UEye": {
"Status": "No UEye driver loaded."
tmp_NxView.zip (4.2 MB)
