- Product: X36
- Serial Number: filecam
- Ensenso SDK Version: 3.6.1621
- Operating System: Windows
I’m trying to apply the command ReprojectPoints from the Python API. Unfortunately I’m having trouble providing the image points using set_binary_data. I tried many different paramter combinations but so far without success. The furthest I get is
with NxLibCommand(CMD_REPROJECT_POINTS) as cmd:
cmd.parameters()[ITM_CAMERAS] = "sequence_001"
cmd.parameters()[ITM_POINTS].set_binary_data(pos.reshape((1,1,2)))
cmd.parameters()[ITM_RECTIFIED] = True
cmd.parameters()[ITM_SENSOR] = "left"
cmd.execute()
which gives an NxLibExecutionFailed Exception. Here, I tried both pos.dtype=np.float32 and pos.dtype=int. Indeed, when I look at print(cmd.parameters().as_json()) it is
"Cameras": "sequence_001",
"Points": 13366972242.714200973510742188,
"Rectified": true,
"Sensor": "left"
so obviously somthing went wrong with setting the points.
Depending on how I combine the parameters of set_binary_data and the shape of pos I get various errors during the set_binary_data call.
Is there a simple example on how to use set_binary_data in python?
