How to implement NxOpenTcpPort in own apps to access camera from NxTreeEdit?
Hi Team,
Issue: Customer is making their apps via MFC (C++).
However when they try to access NxTreeEdit from their Apps, they can only access Debug mode. so they cannot access like Binning or Size parameter. (read only mode)
Camera: Ensenso N36
SDK: 3.4.715
Other Tests: The customer confirmed the following.
It also occurs in Windows 10 and 11 environments.
It also occurs in SDK 3.2.489, 3.4.715, and 3.6.
It also occurs in the sample programs C and C++ included in the SDK.
But it does not occur in C#.
I just modified sample program nxSimple as below for the test.
nxLibInitialize(true);
nxLibOpenTcpPort(24010);
Could you provide any simple sample program?
I tried to reproduce the described behaviour, but I think I need more information to comprehend the actual problem correctly.
Here is what I did to reproduce the case:
  1. I booted a Windows 10.0.19045
  2. I installed Ensenso 3.6.1631
  3. I copied the C++ example folder (In my case located here: C:\Program Files\Ensenso\development\examples\C++) to a location in my user folder
  4. I opened the nxCppEcamples.sln solution with VS2022 and retargeted all the examples (see screenshot)
  5. I modified the nxSimple example as below to enforce the usage of my camera with the serial 244157 and additionally added a std::cin.ignore() to prevent the NxLib from finalizing, giving me the possibilty to access the lib on port 24010:
@@ -31,11 +31,11 @@ int main()
        try { // Use try/catch for error handling
                std::cout << "Opening NxLib and waiting for cameras to be detected" << std::endl;
+               nxLibOpenTcpPort(24010);
+               std::string serial = "244157";
                // Create an object referencing the camera's tree item, for easier access:
-               NxLibItem camera = getAvailableCamera({valStereo, valStructuredLight});
-               std::string serial = camera[itmSerialNumber].asString();
+               NxLibItem camera = NxLibItem()[itmCameras][serial];
                std::cout << "Opening camera " << serial << std::endl;
                NxLibCommand open(cmdOpen); // When calling the 'execute' method in this object, it will synchronously execute
                                            // the command 'cmdOpen'
@@ -69,6 +69,9 @@ int main()
                camera[itmImages][itmPointMap].getBinaryDataInfo(&width, &height, nullptr, nullptr, nullptr, nullptr);
                camera[itmImages][itmPointMap].getBinaryData(pointMap, nullptr);
+               std::cout << "You may access with NxTree now" << std::endl;
+               std::cin.ignore();
                // Compute average Z value
                std::cout << "The average z value in the point map is " << std::setprecision(1) << std::fixed << std::showpoint
                          << computeAverageZ(pointMap, width, height) << "mm.\n";
  1. I started the installed NxTreeEdit
  2. The next step is unclear for me, I have to right click on the nxSimple.exe entry to open it in Debug Access otherwise it would open in default writeable mode.
  3. Both access modes work fine for me and I’m able to edit binning:
What prevents the customer from connecting withTreeEdit to the NxLib in use without using the debug access? Is there any error message? My understanding of debug access is that it is an additional feature and normal access should always be possible if the debug access is.
Joel Kaiser
Hi again,
a colleague of mine gave me a hint about what might be the confusion here.If the customer might want to access via TreeEdit while he has stopped the application that links to the NxLib using a debugger then he cannot access in write mode. Not only the application is stopped, but also the NxLib against which it is linked, so the NxLib cannot respond to TCP requests. In this case you can access the Tree in debug mode, read-only via shared memory (the actual use-case for this debug mode).
I don’t know exactly what differs from the C# application. Either the C# debugger handles stuff differently or the C# application uses a NxLibRemote instead of a NxLib.
Joel Kaiser
Hi Joel,
Thank you for your test and suggestions.
I found that the reason why the customer and I could not connect via NxTreeEdit, it is because we used a breakpoint to prevent NxLib from finalizing.
If I use std::cin.ignore(), it works fine.
Customer has several questions.
  • In other words, you can’t set breakpoints in C++ and C.
  • Is this the same specification as before?
    I used to use Halcon and remember that I could see whenever I opened.
  • Also, looking at the components, it appears to be accessed from nxlibremote64.dll.
    Components Overview — Ensenso SDK 4.1.1023 Documentation
  • Are there any way to access anytime? (by using NxLibRemote?)
so my colleague had the right assumption when he assumed that the application was stopped using a debugger.
I think I should be a bit more detailed about my previous statement:
NxTree is using a NxLibRemote under the hood to display the state of the NxLib executed by the application. The NxLibRemote communicates via HTTP (and therefor TCP/IP) with the NxLib. The api in use can also be accessed via your browser: If you run a NxLib locally on e.g. port 24000 you can open the tree as json in your browser http://127.0.0.1:24000/api/tree
I’ll try to answer the questions:
    You can set breakpoints in a C++ and C application to debug that application, looking at the memory, internal variables and even at the NxLib state with the NxTree in debug mode. A C/C++ debugger stops the execution of the application and all loaded dlls, so it is not possible to change entries in the NxLib using NxTreeEdit on hold.
    I don’t know exactly what is meant by specification, but the behaviour has always been like this and is determined by the debugger used. I don’t use Halcon myself, but I can well imagine that Halcon does not stop the NxLib when a script is interrupted. Using a Halcon script is quite different from using a C/C++ application in terms of debugging. When executing a Halcon script, the actual application (namely Halcon) is not stopped even during debugging, only the interpretation of the script is paused. It is therefore possible with Halcon to continue running the loaded NxLib when pausing a script.
    Yes, NxTreeEdit links against NxLibRemote64 to communicate with another NxLIb.
    If you want to use a NxLib with C++/C application and access the NxLib to modify it via NxTreeEdit while the application is stopped by a debugger you might want to open the NxLib with an additional application that runs the Lib until a stop is requested, e.g. reducing the example to the following:
#include "nxLib.h"
#include "../common/example.h"
#include <iostream>
int main()
      try {
                std::cout << "Press Enter to stop" << std::endl;
                std::cin.ignore();
	} catch (...) { // Display exception, close camera, finalize lib and exit
		exitOnException();
	closeAndFinalize();
	return 0;
The application to debug will use a NxLibRemote instead of a NxLib in the scenario. Take a look at the nxGetLog example how to accomplish this.
With kind regards ,
Joel
