Hardware Compatibility X-Series 1.6MP / 5MP
Having a look at the manual, I assume that X36-2CP (1.6MP) may be used with SDK versions 3.1.480 and later, but until SDK veriosn 3.4.743 the correct firmware is not delivered with the SDK, so the “wrong firmware” warning will be displayed, until the guf-file is copied into the firmware-folder. Correct?
I’m not sure whether I got the phrase “revision x.2” correctly. At IDS we use the term “rev.2” together with the CP housing. (CP Rev.2 housing looks like a cube, the CP housing looks like a cuboid e.g.1.3 MP version uEye cameras)
What hardware revisions are you referring to in [3] - Is there a PCN? (I have PCN 200903 - X3x Rev.2)
I’m confused about the “They require a new firmware version”, because 5MP X-series (5CP) has used GigE Vision firmware from the very first beginning.
Cheers Ute
Hi Ute,
the footnote is about the difference between “Rev.2” and “Rev.2.2” devices. They were introduced during to the chip shortage to update to other electronic components with better availability.
I don’t know if there was a PCN for this.
@ids-ensenso the term x.2 was used in communication from IDS, which we simply adopted. Maybe you can also share the respective PCN from IDS side for this?
