GPIOs X3x-FA - missing doc
Dear Optonic team,
The documentation specifies the GPIOs for the X30/X36 in the IP30 “CP” version.
I guess it would make sense to integrate the IP65/67 “FA” in there
Cheers
Boris
Hi Boris,
how do mean “FA version”? This only defines the pinout on the projection module, which is identical in all versions, regardless of the connected camera.
Thanks Rainer, then the IP65/67 version of the projector module has the same GPIO connector than the IP30? I did not knot that
Yes indeed the projector module is always IP65/67.
