Getting depth map in python
  • Product: N10-804-18
  • Serial Number: 130060
When I use nxview, I get a decent depth map. However, when I switch to Python, my disparity map and point cloud are mostly filled with NaN values. Most of the elements are set to -32678 (indicating NaN). What could be causing this? The save_stereo_image script works correctly, but when I try to generate the disparity map, it produces incorrect results.
Hello Warre,
when you use the camera in Python, do you provide the same settings used in NxView? This transfer does not happen automatically. There is a guide for loading camera settings in the manual, which tells you how to save the settings from NxView and apply them in your application. It does not cover Python, but the principle is the same as in C++:
from nxlib import NxLib, NxLibItem, StereoCamera
from nxlib.constants import *
# Load the parameter file.
with open("params.json") as f:
    jsonstr = f.read()
# Store the parameters temporarily for inspection.
tmp = NxLibItem().make_unique_item()
tmp.set_json(jsonstr);
# Initialize NxLib, open camera.
with NxLib(), StereoCamera.from_serial(serial) as camera:
    # Load only parameters from the file.
    if tmp[ITM_PARAMETERS].exists():
        camera.get_node()[ITM_PARAMETERS].set_json(tmp[ITM_PARAMETERS].as_json(), True)
    else:
        camera.get_node()[ITM_PARAMETERS].set_json(tmp.as_json(), True)
# Clean up.
tmp.erase()
If that did not help you, please let me know.
Hi Rapheal,
Thank you for your response. I have implemented the settings from NxView in my application, but unfortunately, the issue persists.
Attached are two point clouds for reference: one generated using NxView (showing the surface), and the other created using the Ensenso Python example script ‘nx_watch_point_cloud’ (displaying some edges and unusual lines).
nxview
python
Then let’s go figure out why.
Assuming everything works correctly, did you check whether your surface was not just the tiny blue shape in the lower left? Depending on the settings, the NxLib can sometimes generate ghost points in these long lines that can be quite large and overwhelm the actual data if the 3D view is not properly scaled, which the example probably does not do. You can usually get rid of these ghost points by using more aggressive filtering.
If your surface is really not there, we have to go look for it somwhere further up the chain. Please excuse me if it seems like you answered some of these questions already, I repeat them make sure I understand you correctly.
  1. Does the camera produce good data with the default settings, i.e. when you open it in NxView with the Load Cached Settings checkbox unchecked?
If you need to modify any parameters:
  1. Did you save the modified parameter set to a file, either via the Button in the NxView parameter window or NxTreeEdit?
  2. Did you insert the code to load the parameters into the nx_watch_point_cloud.py example so it loads your parameters, if necessary?
  3. Or did you just hardcode the changed settings in the example?
  4. Can you add a call to nxlib.open_tcp_port and check using NxTreeEdit that the parameters are set correctly?
If the parameters are loaded correctly:
  1. Use NxTreeEdit to check the disparity map and the point map in the running nx_watch_point_cloud.py example. They should be similar to the maps you see in NxView.
  2. When you save the images to a file camera from NxView by pressing Ctrl-S or via File > Save > Raw Images, and then create a file camera from the saved images and load that into the nx_watch_point_cloud.py example, does that produce results similar to NxView?
If that does not work, can you please attach you parameter file, the file camera and, if you modified it, your nx_watch_point_cloud.py to your reply?
Thank you for the guidance. I followed each step, and here are my answers to your questions:
  1. Yes, the camera produces good data with the default settings in NxView.
  2. Yes, I saved the modified parameter set to a file, as instructed.
  3. Yes, I inserted the code to load these parameters.
  4. No, I did not hardcode the changes; they are loaded from the saved file.
  5. I added nxlib.open_tcp_port and verified via NxTreeEdit that the parameters are set correctly.
  6. The disparity and point maps are not similar; I will attach images of both for clarity.
  7. When saving images in NxView and loading them in nx_watch_point_cloud.py, the Disparity Map now matches for the first time, and the Point Map matches too, but with the problem you described before: the ghost points in those long lines.
I am also attaching the requested files and confirm that I’m using the original nx_watch_point_cloud.py. Given that the parameters do match, do you have any idea what might be causing this issue with both the Disparity Map and the Point Map?
EnsensoProblem.zip (392.8 KB)
I’ve tried many approaches to solve this issue, but unfortunately, without success. The disparity maps I’m seeing in Python resemble those from NXView, but only when the projector is turned off. In Python, I’ve set the projector to True when using the camera, and I can also confirm in real life that the projector is indeed on when set to True. However, it seems as if the capture() or compute_disparity_map() functions within the SDK internally assume the projector is off.
Additionally, I’m curious as to why I get a correct disparity map when I save a camera file and then read that file back into my script, as described in Step 7 of your previous response.
Thanks in advance!
I am not sure what you mean by this. The NxLib command ComputeDisparityMap only operates on the the image pixels and does not care about the nominal projector status. Command Capture ensures the projector is switch on or off, depending on the setting.
One possible source of error that might be related to the projector is that for the N10 the exposure can only be changed with a delay of one frame, meaning if you change the exposure now, the next frame will still use the previous exposure. Even though you have loaded different settings, since the Python example only captures one frame, it will always use the default exposure, which might not be ideal. Do the images in Python all look alright? You can insert a second capture() call to ensure the example is using the exposure from your settings.
If this does not work, can you send me a copy of your bad point map? You can right click the PointMap node in NxTreeEdit and select Save binary data as…. And possibly also a file camera from the python example. To obtain one you can use the /Execute/Default node to execute the SaveFileCamera command via NxTreeEdit.
I have followed the steps you described, but nothing changes when I perform multiple captures in succession. I have also tested older versions of the Ensenso SDK, but without success.
Attached, you will find the point map I created using Python. It resembles the point map I get with NxView when the projector is turned off. When I try to execute the SaveFileCamera command in NxTreeEdit, I receive the error: “Parameter ‘path’ is missing.” I have included a screenshot of this error in the attachment. Additionally, I am including my Python script for your review. Thank you for your help.
EnsensoPython.zip (101.8 KB)
Hi Warre, the provided image from open3d rings a bell… Please have a look at the camera parameter “EnforceDisparityRange
I was able to get good renderings of the pointcloud after setting this parameter to true.
Unfortunately, this setting doesn’t make much difference for me. The problem is that the camera isn’t generating the disparity map correctly. Attached is a screenshot of the same image where NxView creates a good disparity map, but in Python, I can only see a smal/weird part of the disparity map. Any idea why this might be happening?
Hi Warre, did you try to use the compare function of an editor to find possible differences between a copy of the complete tree (taken out of NxTreeEdit, connected to your Python -exe) and the original tree taken from NxView?
Hi, I’ve checked, and I noticed a difference in the temporary files under ‘Execute’. When I use NxView, I see multiple temporary items like ‘Temporary’, ‘Temporary-0001’, ‘Temporary-0002’, and sometimes up to ‘Temporary-0004’. As far as I can tell, these files include ‘null’ or ‘ComputeDisparityMap’. However, when I use my Python script, there’s only a single temporary item that cycles between ‘null’, ‘capture’, and ‘ComputeDisparityMap’. I’ll attach my Python script and an image of the NxTreeEdit for NxView. Thanks again for your help!
PythonNxView.zip (65.9 KB)
That is normal and expected. NxLib uses multiple execute slots to execute commands in parallel, while your script only uses one.
Sorry, I was not very exlicit there. Path is indeed a required parameter, which you have to add manually below the /Execute/Default/Parameters node before setting /Execute/Default/Command to the string SaveFileCamera, as is explained in the command documentation
I have had a look at your script and could not spot any obvious mistakes. I tried it myself with some real data and I think that the issue comes down to the open3d viewer that we use in the nx_watch_point_cloud.py example just does not handle the usual kind of noisy data very well. It works fine with a nicely optimized scene, like our sample data N35 cast pipe branches:
But a file camera of me holding up a legal pad may look fine in NxView:
but comes out horrible when viewed with an unmodified nx_watch_point_cloud.py example:
It look like there are far fewer points, and it seems also having trouble with the relatively large spread due to all the speckles.
The example just being a toy example, I don’t think there is much more I can do for you here. We might have a look if there there are any obvious improvements we missed when we originally wrote the example, but getting everything right and looking nice is really what NxView is for, which we also distribute as a C++ example, if you want to see how it handles the 3D view.
If you get the python example to look any nicer you can let me know.
Hi Raphael, in my last attached script (‘EnsensoStereo2’) I didn’t use the open3d viewer and the disparity map is still not correct. Could it be a problem with the N10-804-18, because it is an older model? The ‘Capture’ commands look correct, but when the command ‘ComputeDisparityMap’ is send, it gives incorrect results.
If NxView has no trouble with your N10, neither should your script. I used an X36 and the 3D plots look just as bad, although the disparity map in NxTreeEdit look ok.
Do you have the problem only with the N10, or also with file cameras created from the N10 or any of our example cameras? If you open the same file camera with identical parameters in NxView and in your python script, do the disparity maps look substantially different when viewed in NxTreeEdit? If so, can you please provide
  • the file camera, if it is your own,
  • the exact python script and settings file you were using,
  • screenshots of the disparity maps from NxTreeEdit for both NxView and python,
    • (for a larger view, you can double click the preview or right-click on the DisparityMap node and select Show binary data)
  • copies of the JSON tree for both NxView and python?
If everything works with the file camera, maybe I will have to dig up an N10 from the basement and try it myself.
