- Ensenso SDK Version: starting with SDK 4.3
- Operating System: Linux / Windows
Hello Ensenso team,
Does the GentL producer also allow to use Ensenso cameras in Merlic?
Hello Ensenso team,
our GenTL Producer supports version 1.6 of the protocol. We do not guarantee that it will work with the full range of possible applications on the other end. However, I see no reason why it shouldn’t work if MvTec supports the GenTL protocol.
You have two look it up in the manual of your merlic version if 1.6 is supported.
Regards
Joel
Hi Joel, thanks you for your fast response. I’ll check out the infos on the MVTec page. If there will be any news that might be interesting for the community, I’ll drop it here.
Regards Ute
