We just released Ensenso SDK 4.3.991 and B-/C-series firmware 2.0.151. They are available from the download page .
- GenTL Producer: Improve compatibility with Aurora Design Assistant / Matrox Imaging Library and Halcon.
- Fix a bug where one of the sensors of a B- or C-series device could sometimes not be initialized and was missing after booting. When this happened the device would show up in multiple parts in the NxLib and was flagged as uncalibrated. Requires an update to firmware 2.0.151. [#6344]
- Fix discovery of B-, C- and CR-series devices while there are conflicting IP addresses on network adapters on Windows. [#6288]
- Fix a bug where the previous value of MultiExposureFactor was used when closing and re-opening a B-, C- or CR-series stereo camera, even when explicitly resetting it to 1 after re-opening. [#6306]
- Disable automatic white balance on color sensors by default. This was meant to be the case since version 4.3.880 and was already mentioned in the upgrade notes, but was not active due to a bug. [#6303]
- Use the correct aperture for B57-/700- models in GetModelInfo. [#6312]
- NxView: Fix the selection of stereo matching algorithms for XR-series cameras. [#6355]
