We just released Ensenso SDK 4.2.1821. It is available from the download page .
- NxLib: Fix a memory leak while
/Debug/Levelwas set to"Off". [#5990] - NxLib: Stereo cameras with color sensors now have separate white balance parameters for texture images. The existing white balance parameters only apply to the projector images.
- NxLib: PartFinder: Fix a possible occurrence of
cudaErrorIllegalAddressin theFindfunction when CUDA was enabled. [#5996] - NxLib: PartFinder: Fix a bug where model creation could fail with the message “Mismatch between masks and templates” when using
CropRegions. [#5991] - NxLib: ComputeDisparityMap/RectifyImages: Fix a bug where the command could use more threads than allowed. [#6013]
- NxLib: ComputeDisparityMap: Fix a possible out of bounds access when using a very small AOI with SGM or correlation matcher. [#5970]
- NxLib: SimulatePhysics: Fix a bug where the object pose was sometimes not updated correctly. [#5981]
- Halcon: Fix an undefined symbol error when loading the Halcon interface library with newer Halcon versions on Jetson. [#5998]
- The GUI tools now start correctly when there is an incompatible version of Qt in
$LD_LIBRARY_PATHon Linux. [#5964] - Various bugfixes for Engage.
