We just released Ensenso SDK 4.1.976 and B/C-series firmware 1.4.49. They are available from the download page.
Highlights
PatchMatch2
Delivering dramatically enhanced point cloud details, the same unmatched robustness on challenging surfaces as PatchMatch1, and a streamlined setup with 5 fewer parameters!
Enhanced details captured with PatchMatch2 — notice the clearly defined teeth on the worm gear and the much sharper edges throughout the scene, demonstrating the precision and clarity of the improved algorithm.
PatchMatch2 excels at capturing intricate details — note the sharper edges and the accurate reconstruction of small holes.
Image Enhancement
Image-enhancement removes color distortions and improves the overall image, resulting in a more vivid, true-to-life, and visually striking point cloud.
New Features
- C-Series: Add support for sensor AOI (requires firmware version 1.4).
- NxLib: The new command
SaveCameraModelexports a 3D model of the camera and its field of view for use in CAD construction. The export is also available in NxView. - NxLib: PartFinder: The reference perspective can now be a monocular camera. This allows to use edges which are better visible in a color camera.
- NxLib: PartFinder: Add a new parameter
ComplementViewpointsto theGenerateModelfunction, that allows to distribute model viewpoints over a band-like area. - NxLib: ComputeTexture: When texture mode is enabled, the
ComputeTexturecommand now rectifies raw texture images instead of computing a texture image from rectified images. This allows to use the command regardless of whether texture mode is enabled or not. - NxLib: RenderView: The size of points can now be computed automatically to achieve an opaque rendering at any depth.
- NxLib: RenderView: The new point cloud rendering mode
Circlesreduces rendering artifacts on colored point clouds. - NxView: PartFinder: Draw coordinate system axes at the position of the origin of the CAD model.
- The Windows SDK is now available as a zip file.
Bugfixes
- NxLib: Fix unstable auto exposure for B-series and C-series cameras (requires firmware version 1.4).
- NxLib: Fix handling of large file camera zip files.
- NxLib: Fix a bug where the binary format of a node could not be changed after a call to
nxLibSetBinaryDataFormatted. - NxLib: PartFinder: Fix a bug where PartFinder models saved from a real camera could not be loaded with the corresponding file camera.
- Examples: Fix the NxView example so that it can be built again without errors.
