We just released Ensenso SDK 4.0.1502. It is available from the download page .
- NxLib: Fix a bug where NumberOfDisparities was clipped to a maximum of 256 even when the current matching method supports an infinite range. [#5356] (00205837)
- NxLib: Fix the error message
Image capture canceledinstead of a normal capture timeout when retrieving an image after acquisition was canceled by execution of another command. This could occur in NxView when switching to the Tracking or Workspace Calibration tabs. [#5352] (00205819) - NxLib: Fix a bug that could cause capture timeouts on some GigE Vision based cameras when the frame ID overflowed after capturing 65536 frames. [#5207] (00204900)
- NxLib: Update X-series projector firmware to version 37 to fix incorrect FlexView sequence when using automatic texture capturing. [#5336]
- NxLib: PartFinder: Fix incorrect false positives with high texture score when using combined refinement. [#5306]
- NxLib: PartFinder: Fix incorrect random filtering of hypotheses when CUDA was enabled. [#5293]
- NxLib: PartFinder: Fix a possible occurrence of
cudaErrorIllegalAddresswhen CUDA was enabled. [#5304] - NxLib: Fix a bug where the status of a newly opened camera was not updated in the tree when an XR-series device without sensors was present in the network.
- NxLib: Fix issues when trying to use file cameras from S-series devices.
- NxView: Fix a potential crash in the focus step of the calibration wizard.
- NxCalTab: Add additional reference points to Ensenso patterns.
