We just released Ensenso SDK 3.6.1631. This is a bugfix release.
- NxLib: Add support for Ensenso patterns on 4mm glass.
- NxLib: Fix X-series projector timeouts under Linux. Updating the firmware and opening the camera sometimes failed with packet timeouts. [#5023]
- NxLib: Fix a bug that could cause capture timeouts on some GigE Vision based cameras when the frame ID overflowed after capturing 65536 frames. [#5207] (00204900)
- NxLib: PartFinder: Fix incorrect false positives with high texture score when using combined refinement. [#5306]
- NxLib: PartFinder: Fix incorrect random filtering of hypotheses when CUDA was enabled. [#5293]
- NxLib: PartFinder: Fix a possible occurrence of
cudaErrorIllegalAddresswhen CUDA was enabled. [#5304] - NxView: Fix a potential crash in the focus step of the calibration wizard.
- XR-Firmware: Fix recalibration for cameras with large epipolar correction. [#5375]
