After upgrading the Ensenso SDK to version 4.1.1033, we noticed that the NxLib/camera_cache.json file and possibly other temporary/cache files are now created in the %ENSENSO_INSTALL%/settings directory.
We would like to store these files in a different temporary directory instead of the SDK installation directory.
Is there a way to change only the cache file’s save location without modifying the ENSENSO_INSTALL environment variable?
This is an undocumented feature and your settings will be placed in /your/new/folder/settings. If you want to use another SettingsFolder in e.g. NxView you can set the NXLIB_CONFIG_TREE environment variable while calling it, NXLIB_CONFIG_TREE='{"SettingsPath": "/your/new/folder"}'. NxView and its NxLib will use /your/new/folder/settings in this case too.
A new Version of ensenso sdk will be released very soon and it will have additional options. You will be able to use the 4.2 ensenso sdk as a portable version by unpacking an archive that can be used independent to other ensenso sdk installations using an settings folder inside the unpacked archive.
