Capture only left monocular camera
  • Product: B57
Is it to possible to capture only images from the left monocular camera (for increasing transferrate between camera and host) - I know that the command “Capture” will trigger left and right monocular camera. But is there a way using the GigEVision / GeniCam protocol?
Currently, it is not possible to capture images from only the left monocular camera using the “Capture” command via NxLib, as this will always trigger both the left and right sensors. However, yes it should technically be possible to access and capture images from a single sensor if you interface directly with the left or right camera using the GigEVision protocol. But in doing so means the camera cannot be used by the NxLib at the same time.
Support for single-sensor image capture via NxLib is planned for a future release, but there is currently no confirmed timeline for its availability.
