Sorry, I overlooked the different N-Series model name. The camera types looked suspiciously like the default text of our question template.
If both cameras show the same erroneous behavior then you might have to do some network configuration. We have a guide on network performance that helps you make the correct settings under Linux. Let me know if that fixes your problem. If not, please provide us with some details on your network setup.
By reducing the network bandwith, I get the images, but I need about 1 s (1 Gb/s, MTU 9000, TX/RTX 4096, no energy saving). Instead in Windows 200/300 ms are sufficient.
I’m using a direct connection at 1 Gb/s (verified with ethtool). The N device is powered by PoE, instead the C device by means of an external power supply able to deliver more than 200 W.
could you please record a log file while the camera is running and trying to receive the images? You can send me a PM with the log file if you don’t want to post it here publicly.
There seems to be a problem with your network adapter. The packets are arriving, but with some pauses in between, so that the overall capture duration is exceeded. Do you have a chance to test another adapter on that machine or even on another Linux machine? Could you also tell us which adapter you are currently using?
At the moment I don’t have a different adapter or a different PC to test, I’ll try to find one.
In any case, in your experience is the behavior under Linux expected as the behavior under Windows, so that this issue is related to a particular HW/SW configuration on my PC?
yes, if the camera properly works on Windows we also expect it to work on Linux. There is always the possibility of a bug in our firmware which could lead to diverging behaviors between the two OS, but since the packets are arriving on your machine as I stated above, this looks like the problem is linked to your current machine.
I am glad to hear that it works with a different PC. Since the problem is not related to our hardware, there won’t be any further investigations done by us. If something similar will come up in the future and there seems to be a solution, we might remember and update this issue.
Thank you so much for your assistance. I am currently facing the same problem and I don’t know how to bypass it. If you have any solutions from your side, please let me know.
It seems that Alessandro’s problem was with the Ethernet adapter or its Linux driver on their laptop. If you have a similar issue, I suggest trying to identify the cause.
Is the problem related to the camera? If possible, try using a different camera.
Is the problem related to the operating system? If possible, try using Windows.
Is the problem related to the computer itself? If possible, try using a different computer, preferably one with a different network adapter and not a laptop.
