To allow shorter exposuretime when capturing calibration targets, it would be nice to change the color of the frontlight from white to blue.
Hi Ute,
we probably don’t want to create another variant of the device by that, but we will check if we can improve the output power for the diffuse flash in the blue light region. Actually the front light has quite a bit less output power than the projection LED, so there might be simple options to switch to another type for a future hardware revision.
Do you have any numbers (e.g. exposure times) to share, and a target where you would like to get in your use case?
