I’m trying to enable CUDA support but haven’t been able to figure out how, even after going through various parts of the documentation. I’m using the camera via Python in Visual Studio Code.
It’s probably a straightforward process, but I’d appreciate some guidance on how to set it up properly.
on most platforms, you can and must explicitly enable CUDA by setting the tree node /CUDA/Enabled to true. The value of this node is used by most CUDA-enabled commands as default fortheirrespectiveCUDA/Enabledparameters.
The python code for setting the node would be:
from nxlib import NxLibItem
from nxlib.constants import *
NxLibItem()[ITM_CUDA][ITM_ENABLED] = True
If you still find that CUDA is disabled, you can check whether NxLib reports it as available and there is no error.
