Hi all,
I have a question and would like to hear your opinion on this topic. We are exploring solutions that can give a volume estimation for bulk feed. I did some initial tests with a ZED 2.0 camera to give an idea about the environment. The 3D output (mesh and pointcloud) are shown below.
The camera will eventually be mounted on a vehicle that drive alongside the feed. The scene is stationary, except for the cows and the camera is continuously moving. We can perform computations on the data on a computer.
Based on the above description what would be interesting camera’s from Ensenso that we should consider?
Hi @wilcobonestroo
thank you for the images of the application. Before we can give advice on the camera type it would be interesting to know more about the following aspects:
- motion speed of the vehicle
- distance of camera to object (min/max)
- required view field size in a single image
- required XY and depth accuracy
Can you give us some rough estimates on these topics?
Best regards, Rainer
Dear @wilcobonestroo ,
thanks for the additional details. That looks like the effective 3D requirements are rather coarse. You can probably go with an N-Series camera, which is available with many different view fields, or a B-Series. The latter comes with RGB sensors and a very wide viewing angle and depth range. This might even be the most flexible option in your case. Here is a link to the specs in our camera selector: B57-4-GN.
Can you provide me with a quote for the and the N30, N31 and B57 at w.j.bonestroo@saxion.nl
@wilcobonestroo I forwarded your request to your local sales contact yesterday and you should receive a quote via email quickly.
