Dear Optonic support team.
Does XR model support 2.5Gbps uplink as X-series does?
If it supports 2.5Gbps, can I expect faster transmission rate if host receives 3D data as well as captured image?
Thank you.
Thank you.
Dear unidentified IDS employee,
the XR only supports 1G wired ethernet. Any performance gained in transmission over the X-series is due transmitting only 3D data and no (or only fewer) images.
Dear Raphael
This is Brian from IDS Korea.
Thank you for your clarification
