Required power supply specifications
Hi
Thank you for your reply. I am currently using a C57-6-M, so if I can purchase a 10m M8 cable (0.5 mm²), I plan to cut it down to 5m for use. If the voltage drop with this cable remains within an acceptable range, I assume an M12-M8 adapter cable would not be necessary—what do you think?
Please let me know if I am mistaken.
Hi techno,
If I had to order new cables, I would use an M12 cable with the adapter https://de.ids-imaging.com/store/adapter-power-supply-ensenso-xr-to-x-0-2-m.html. But if you have all needed cables at site and it works, than I would keep using the stuff I already have.
Cheers Ute
Hi Ute
I appreciate you sharing the M8 to M12 adapter cable.
Do you also offer M12 drag-chain-compatible cables (5m or 10m) that can be connected to this product?
Additionally, could you please provide your company’s specific part number for the following item?
M12 5-pin cable (open-ended)
Optonic Part Number: 11144 (5 m)
Hi Benjamin
Regarding Optonic part number 11144 (M12 5-pin cable, 5m, open-ended), what is the cable length?
I am not sure if I understand the question correctly. The length is 5m as you already wrote above. See the cable’s specifications for more information about other available lengths and the wire’s cross sectional area.
Hi Benjamin
Apologies, I provided the wrong link.
I couldn’t find any information regarding the length of the adapter cable below, which is why I asked.
Adapter Cable: M12 5-Pin - M8 4-Pin
Optonic Part Number: 11078
You are right, the cable length is not mentioned in our manual. It is 30cm. I will update it accordingly.
