Product
C67-616975-S7-BL (C67-5M8C-6/16|8/28|3.7/28|975-240/7-BL)
Serial Number
EnsensoSDK Version
4.3.991
Operating System
windows
Describe issue here
I’m playing around with a C67 in a small test setup and I’m trying to get hardware triggering to work. I’ve been stuck on this for a while, so hopefully someone can point me in the right direction.
What I’m trying to do:
1. first trigger → stereo camera takes the depth image (projector on)
2. second trigger → color sensor takes the color image, while I fire my own external flash
The flash messes up the depth pattern, and without flash the color image is too dark. So I’d like to decide myself when the color image is taken. I’m using a microcontroller to send a 24 V pulse to the trigger input on the GPIO connector.
What happens:
When I set Parameters/Capture/TriggerMode to “RisingEdge” or “FallingEdge”, it just jumps back to “Software”. No error. Same result:
- on the stereo camera (260778) and on the color sensor (260778-Color)
- from my own C# code and by hand in NxTreeEdit
- with live capture in NxView stopped
Only “Software” and “Internal” stick.
I also can’t find the flash output: Parameters/IO/Output/Mode doesn’t exist on the color sensor (ItemInexistent). Under Parameters/IO I only see: [fill in].
I saw in topic 1394 that someone uses “FallingEdge” on a C57 and it works there, so I expected it to work on the C67 too.
My questions:
1. Does the C67 support hardware trigger on the GPIO trigger input? If so, from which firmware / SDK version, and how do I switch it on?
2. Can the stereo camera and the color sensor each get their own edge or pulse (e.g. stereo on the rising edge, color on the falling edge)?
3. If not: with stereo hardware-triggered and color on “Internal”, how long is the delay between the two exposures, and is it constant?
4. How do I enable the flash output for the color exposure, so an external light can follow it?
Thanks a lot!
